running calculation with film
Bert
Post by Bert »
I recently moved WUFI 5.1 from my laptop (XP) to my desktop (Windows 7)
When I run calculations with film, it seems to work just fine, until I try to change properties to IP. I have IP set as default, should it not carry that over to the film?
It hangs up and I have to use task manager to close the program.
Any Ideas?
Bert
Bert
Post by Bert »
looks like the problem is with Animator1d, NOT WUFI.
Running 64 bit machine.
Hello Bert,
I have a Win7 64 bit machine, too and just tried to use WUFI and Animation1D in IP for WUFI Pro 5.1 and see no problems.
I think there is a special problem on your machine. Maybe some "Virtual Store" issues.
Bert
Post by Bert »
Manfred,
did you try to change "properties"?
It runs fine as long as I leave the props set to metric.
It locks up the second I hit the properties button.
Bert
Bert
Post by Bert »
Manfred,
my apologies. should have read your post better.
I see where you did try changing to IP.
Our IT department has no idea what's going on.
What do you mean by "Virtual Store" issue?
Bert
Bert
Post by Bert »
Manfred,
that's not the problem. I have full administrative rights and there is no folder called virtual store.
I did download and re-install this morning, but it did not change anything.
As soon as I select "properties", it locks up.
Apparently something on my end, but unable to figure it out.
Bert
Try to delete the file Animation1D.kfg, which is located in the same folder that Animation1D.exe
Bert
Post by Bert »
nope, doesn't do it either. Tried it yesterday and again this morning.
Bert
Post by Bert »
Guten Morgen, Manfred,
Issue resolved. I have a dual monitor setup and somehow the screen where you change properties disappears into la-la land.
Everything works fine when I set it to single monitor.
Thought I'd let you know in case somebody else has the same problem.
Not sure yet what settings to change to make it work.
Bert
Oh, and go Dortmund!
