I recently moved WUFI 5.1 from my laptop (XP) to my desktop (Windows 7)
When I run calculations with film, it seems to work just fine, until I try to change properties to IP. I have IP set as default, should it not carry that over to the film?
It hangs up and I have to use task manager to close the program.
Any Ideas?
Bert
running calculation with film
Hello Bert,
I have a Win7 64 bit machine, too and just tried to use WUFI and Animation1D in IP for WUFI Pro 5.1 and see no problems.
I think there is a special problem on your machine. Maybe some "Virtual Store" issues.
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
Please see here:
http://www.wufi-forum.com/viewtopic.php?t=328
Enjoy WUFI®
Enjoy WUFI®
Manfred,
that's not the problem. I have full administrative rights and there is no folder called virtual store.
I did download and re-install this morning, but it did not change anything.
As soon as I select "properties", it locks up.
Apparently something on my end, but unable to figure it out.
Bert
Bert
Guten Morgen, Manfred,
Issue resolved. I have a dual monitor setup and somehow the screen where you change properties disappears into la-la land.
Everything works fine when I set it to single monitor.
Thought I'd let you know in case somebody else has the same problem.
Not sure yet what settings to change to make it work.
Bert
Oh, and go Dortmund!
Bert
