CreateClimateFile.xls
Peter Brander
Where can I find the tools folder and CreateClimateFile.xls
Trying to create a wac file but its hard without the excel sheet
Skanska Sverige AB
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Besök: Drottningtorget 14
Tfn: +46 10 4483410
Fax: +46 40 237047
Mobil +46 70 6967173
E-post: Peter.Brander@skanska.se
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Peter Brander
wac files one year limit
Thank you. I found it in another mail reply later on.
Now i have created a couple of WAC files and then some other questions came up.
How can i get the correct year presented in the wac data or is this alwyas a synthetic year? This is also relevant when my measured data have different starting time for month, day, and hour as well.
In the excel tool i can put in more than 8760 rows of data and the tool will create the wac file including this data. When importing into WUFI I get a warning message that i have more than one year of data but the computing works fine. How does WUFI handle the excess data.
And finally
I have eight years of pretty complete data. What fileformats will work for the whole period in WUFI and what format do you recommend
And finally
Skanska Sverige AB
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Dear Peter,
note your correct year in the Description, it is anyway not of further interest.
First line in the Excel sheet must be 1.Jan 1:00 and you have to have at least 8760 lines hourly.
WUFI does always read to the end of a climate file and then jump to the first line.
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
Peter Brander
calculation period in the wac file
Now I produced a 4 year file 19900101-19941231 (ran out of excelrows to be able to include eight years) .
When I am choosing my calculation period 20090401-20120331 (as I had in calculation previous ) there is no indication in WUFI that this should be a problem. I was expecting year 1-4 based on the wac file. Based on that o got confused about how to sort out different calculation periods within the data period. Is Wufi starting up the calculation properly in april or is the first line of data chosen?
Skanska Sverige AB
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Just once more; First line of the Excel Sheet must be 1.Jan 1:00
If you run out of Excel Lines use 7 years first and copy the year no.8 into the WAC file by using a text editor.
You can not select a calculation period, you can just select the start date.
Enjoy WUFI®
Enjoy WUFI®
Peter Brander
calculation period
Big thank you for rapid resons
Just to be clear.
As I understand from the discussion WUFI always start calculation in year one on the correct date with wac files(looking ok in my resultfile).
This mean I have have several wacfiles för the period if i want to start calculation in year 2-8
Just to be clear.
Skanska Sverige AB
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
