Give material input to WUFI through the command line
Noelie
Post by Noelie »
Hello Forum,
I would like to use WUFI to simulate an experiment I made. However, in this experiment I don't know the exact diffusion resistance factor of my material. Thus, I want to use an iterative process to obtain the best diffusion factor which would fit my experimental results. For that I plan to use WUFI in batch mode in order to control it directly through command line.
Is there a way to change the diffusion resistance factor of my material and the initial relative humidity conditions directly via command lines?
Thank you :)
Re: Give material input to WUFI through the command line
Sent you a pm.
