Results graphs - Dew point report
james bertram
Post by james bertram »
Can you suggest how to add a graph similar to the Quick Graph "Temp/Humidity" with Dewpoint activated.
Can't seem to find the option in the Results Graph menus.
Thank you.
Re: Results graphs - Dew point report
Hello James,
unfortunately that is not possible at the moment. We plan that for later versions.
The second possibility to display the dew-point for a special position is to go to the animation viewer, set the display of the dew-point in the settings. After that it will be shown in the course view for each grid element.
james bertram
Thanks Christian - will give that a go.
