I´m using sources and sinks to simulate different rates of airchange in a ventilated airgap inside an exterial wall. 5,10,25,50 and 100 changes per hour is used. When i calculate I see that the temperature profiles inside the airgap is identical regardless of ventilation rate. I expected the temperature difference between outside air and airgap air to be very ventilation dependent.
What have I missed?
Diffrent airchange in airgap doesnt effect air temperature
Peter Brander
Skanska Sverige AB
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Besök: Drottningtorget 14
Tfn: +46 10 4483410
Fax: +46 40 237047
Mobil +46 70 6967173
E-post: Peter.Brander@skanska.se
Peter Brander
Teknik
Byggfysik
www.skanska.se
205 33 Malmö
Tfn: +46 10 4483410
Fax: +46 40 237047
Dear Peter,
there need not to be a fault. If the air change rate is high enough, the exterior climate conditions will be reproduced in the ventilated cavity. Look at the "Senaste Bräkning" where you can find the integral of all Heat and Moisture Sources.
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
