WUFI 3.5 won't start in win 10 Parallel VM
All about WUFI Passive
sullyfoos
Post by sullyfoos »
Hi, I've read the posts on startup issues and have tried the solutions.
I created a new Parallels Windows 10 install, built with default config, and exceeds window specs on WUIFI requirements.
Installed .net framework, sp 1, before installing WUFI.
Installed the free versions of WUFI 3.5. The database appears to be in the folder.
The application splash screen comes on for about 5 seconds and goes away. No warning messages
Any ideas?
thanks...sullyfoos
WhitneyArchitecture
Re: WUFI 3.5 won't start in win 10 Parallel VM
Post by WhitneyArchitecture »
I have the same issue. Did you ever find a solution for this?
srinivass
Post by srinivass »
I have been trying to troubleshoot WUFI Plus not loading on a new PC which more than met the minimum requirements since yesterday. I tried all the steps advised on the forum. I installed Office 365 on the PC and WUFI Plus opened normally after that. Hope it works for you too.
Thank you.
Shanti
tgoodhart
Post by tgoodhart »
See the forum here: viewtopic.php?t=2113
Recent versions of Windows do not include the x86 C++ runtime, which WUFI requires. Installing the following will allow WUFI to start: https://aka.ms/vs/17/release/vc_redist.x86.exe
This runtime was likely installed under the hood as part of the Office 365 suite, which is why srinivass was able to get things working.
