Good morning,
I'm a beginner with WUFI and have a problem in making the software following the design condition I set.
In the panel design condition, I set min T at 20°C and max. T at 26°C. Similarly I've chosen a min and max for humidity.
Then I defined a heating system, cooling and mechanical ventilation in the HVAC panel.
But when running the simulation, the inner air temp. is maintained constant at 20°C all the year long.
Even if in summer the outdoor air temperature is higher than 20°C the inner air temperature is always constant on 20°C.
I would expect it to vary into the range of 20 – 26 °C as I set in the « Design conditions ».
How can i solve this problem?
GiGal
