Cooler Construction Analysis
C. Furtaw
Post by C. Furtaw »
This may be a different use for WUFI but I thought I would ask.
Can I use WUFI to analyize the following deck section:
The inside of the cooler floor is 4" of concrete on a metal deck with the temp. at a constant 47.5 F. The exterior (but inside s building) or other side is 6" of insulation where the temp. may vary from 70 F to 100 F. The RH is 80%. Obviously there is no rain or wind. Can WUFI be used to analyize the moisture between the two materials? How do I set the various parameters to suit these conditions?
Thanks,
C. Furtaw
Charles E. Furtaw, P.E.
