Could you please tell if it would be possible to model an air exfiltration into the wall assembly using the transient from file moisture source? I have pre-calculated air flow rate [m3/s.m2] based on the wind speed/direction, stack effect and mechanical overpressure, so I was thinking to define the transient moisture source that would depend on indoor water vapour concentration (temperature and RH). Can you please tell me if this is a good approach or would you have any other suggestions? Would the source still be dependent on Water vapor saturation concentration corresponding to the temperature at the deposition site, as it is the case in IBP model?
Thank you very much,
Marko
