Hello
I am working on WUFI Plus 3.0.3 version, but i already have the 3.1.0 version file available.
My question is:
Is this (3.1.0) an update execution file or an new program instalation file?
I mean, shall i uninstall the other version before installing the new one?
And, as i am at the middle of my work, if i repent, can i install the 3.0.3 version again and work on the same files back again? (in the case of having important differences on my simulations, from both versions)
And, by the way, shall i expect important differences using the new version 3.1.0? Do you recommend to install the new version for someone that is in the middle-ending of the PhD work?
Thank you very much in advance.
Sílvia Magalhães
Wufi Plus 3.0.3 vs 3.1.0
Sílvia Magalhães
FEUP, Oporto
FEUP, Oporto
Re: Wufi Plus 3.0.3 vs 3.1.0
Hello Sílvia Magalhães,
the actual release version is 3.1.1
you can find the release notes here:
https://wufi.de/en/software/wufi-plus/w ... e-updates/
normally i recommend to use the same version for one project, but in case of a PhD-work...
There are some minor bug-fixes, might result ins not equal results.
Project files saved in a newer version are not openable in older versions.
You can backup your project files before install the newest version. I's always a 'new installation', but you don't have to deinstall the older.
Thank you very much for the answer.
Sílvia
Sílvia
Sílvia Magalhães
FEUP, Oporto
FEUP, Oporto
