Hello
To see the results, I use Wufigraph, open from Wufi2d.
However I cannot close the software afterwards.
When I want to close the Wufigraph, I get the window "wufigraph.xml (Access is denied)". I have to switch off the PC to get rid of the wufigraph page.
By the same token, I get the following window in Wufi itself when I wish to save results:
"could not save the result file. Please stop the calculation and /or quit all program accessing the result file".
How to solve the problem?
Thank you
Problem in closing Wufigraph 2.4.12
Access is denied
Hi Michel,
this is because of insufficient privileges. Adjust the privileges (allow yourself fullcontrol) and the program will close.
Veit
Veit
Re: Problem in closing Wufigraph 2.4.12
If you are administrator, you have to run WUFI 2D explicitely with elevated privilegues. To do so, right click on the link and select "Run as Administrator". All follow up sub tasks, e.g. WUFIgraph will then run in admin mode, too
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
