Installation of VTT
hbreaux
Installation of VTT
Post by hbreaux »
I'm using WUFI Passive/Plus and need to use VTT. However after I install VTT it does not become available as a post-processor. I've checked wufi.ini and it seems to point to the correct place. Any help would be appreciated.
Sebastian Boegl
Re: Installation of VTT
Post by Sebastian Boegl »
WUFI VTT or WUFI Bio should be displayed in the Film viewer (take a look at the help topic Assessing the results)
hbreaux
Post by hbreaux »
Thanks, Sebastian. That's where I was looking. I presume VTT should show up as a button like WUFI Bio typically should. Although after installing Bio I stil don't see either in the extended animation window.
hbreaux
Post by hbreaux »
Also, WUFI Bio doesn't show up anymore either.
Sebastian Boegl
Do you have any luck showing the post processors by clicking on the right button named "Extended animation"?
hbreaux
Post by hbreaux »
No, it's not there. Once I open the extended animation, which opens WUFI Animation 1D, I don't see Bio nor VTT buttons on top menu bar as expected. But both Bio and VTT have been installed.
Sebastian Boegl
Please try the following to get this working:
  • Append the following to the file %PROGRAMDATA%\WUFI\wufi.ini:
    Code: Select all
    [WUFI6]
    PostProcessorPath=C:\Program Files (x86)\WUFI\PostProc\
    If you are unable to save the changes to the file, save it under a different name such as wufi-new.ini, delete the old wufi.ini and rename the file to wufi.ini.
  • In order to run the Postprocessors download and install the latest WUFI-JRE from here.
hbreaux
Post by hbreaux »
Thank you!
I installed WUFI-JRE64 and added that bit of code to wufi.ini. That seemed to have worked.
furniturefarmer
Post by furniturefarmer »
I have this exact same problem. Would it be possible to explain a bit further how to do this? For instance where do I find this file:%PROGRAMDATA%\WUFI\wufi.ini? and how exactly do I append it?
furniturefarmer
OK, I figured it out. Sorry I'm not a Windows user so it took me a while!
hbreaux
Post by hbreaux »
I've gone through these steps again for a new machine because I experienced the same issues initially.
But, now then I click VTT (now FinMould) and then a material layer in WUDI Animation 1D, the FinMould/VTT splash screen appears onscreen for a split second, but the app does not come up afterwards.
No idea what could be happening. Any help would be appreciated.
can you please send us the logfiles to "support at wufi dot com".
You can them in the folder:
Code: Select all
%appdata%\wufi\logs
Just insert that into your file explorers address field.
Please send wufi7.log and vtt.log from a date, that happened.
Madonna Stewart
Post by Madonna Stewart »
Hi Christian
I have had the exact same issue with VTT (Fin Mould). After upgrading my computer and restarting WUFI I had to re-download and install the Fin Mould processor and then I also had an alert to re-install Java to run the program.
Now I am in the same position as 'hbreaux from 29 oct 2025", where I click on the VTT icon, then select a material layer in WUFI Animation and the VTT screen appears for a split second before disappearing. Was there a solution that came about from looking through the log files?
Any guidance appreciated,
thank you, Madonna
This might be related to missing Java or Visual Studio Runtime.
Please try install the following:
https://wufi.de/download/WUFI-JRE64_8.exe (Java Runtime)
https://aka.ms/vs/17/release/vc_redist.x64.exe (Visual Studio Runtime)
