I'm using WUFI Passive 3.0.0.0 on Windows 7.
When I try to input climate data (for Arlington Virginia) on my Localization tab, I select "From map" hit "Browse" and get an unhandled exception error...
"The Microsoft Jet database engine cannot find the input table or query 'WP_ClimateDataset'. Make sure it exists and that its name is spelled correctly."
How do I load in this climate data file or even find this file, or get this file?
Thanks.
Chris
Missing climate data for 'From Map'
ChrisBriley
Re: Missing climate data for 'From Map'
Hello Chris,
have you used an erlier version of WUFI Passive? And for installing WUFI Passive 3.0 was there an error at the end of the installation, was the WUFI-DB.exe delivered with the Install_WUFI_passive.exe in the same folder? This error can occur due to an old Database version.
For the montly climate data, you might contact PHIUS: http://www.phius.org/wufi-passive-tools ... -data-sets
for hourly dynamic climate data you can find addtional information here: http://www.wufi-wiki.com/mediawiki/inde ... ls:Climate
