I have been reading "Moisture buffering effects on indoor air quality - Experiments and simulation results" and would appreciate some clarification on how to best model acrylic paint as an interior surface coating on a wall.
The paper states "...paint on the surface (2 x acrylic) acted almost as a vapour barrier and effectively limited moisture transfer between the structure and the indoor air..." and also that the "surface transfer coefficient" probably has a bigger effect on reducing vapour flow than permeance.
Given the above, can I use "Surface transfer coef / Interior surface / Sd value" to replicate the likely affect of a primer (alkyd) + 2 x coats of acrylic paint on the interior surface, and if so, what setting would allow for the combined affect of the above factors?
Thank you
