Isoclad and Isofoil Materials?
holyspidoo
Post by holyspidoo »
Has anyone been able to reproduce the ISOCLAD and ISOFOIL products from http://www.isolofoam.com/ ?
Both are Expanded polystyrene insulation, but one has a laminated air barrier, and the other has a vapor barrier (for inside use).
Not quite sure how to enter those into WUFI...
holyspidoo
For Isoclad, I figure the membrane is like Tyvek, so I added spun-bonded polyolefin membrane on the exterior side.
For ISOFOIL, I'm adding PE membrane on the inside of the Expanded poly.
Post by Manfred Kehrer »
I would recommend to use the EPS from the database and use a membrane additionally where you only would have to change the permeability value.
Unfortunately you can not change the material properties in the free version.
