Dear Team,
I am wondering what critical limit IBP use for RH at the IWI/masonry interface for a woodfibre based insulation like Steico, Pavatex, Gutex, Homotherm etc. The (presumed) absence of oxygen should mean that the limit is higher than 80%RH, but do you have a safe limit to work to when assessing the results? Any reference-able material would be appreciated.
I am using the RH assessment in addition to assessing the water content by mass percent of the 5mm woodfibre interface layer for critical levels stated in your training literature of >18-20%
Many thanks in advance for any information
Critical RH limit for woodfibre IWI at masonry interface
Browne Dan
RH limit beneath interior insulation
In Germany there are different limits in discussion. The WTA guideline for interior insulations recommends to limt the RH to 95 %.
To avoid mould growth for sure a complete adheseion of the insulation to the substrate is required.
Accoding do Viitanen at 95 % RH and below 10 °C no wood
decay can occur.
best regards
best regards
Browne Dan
