Hi guys,
I have recently moved from working with WUFI Pro to WUFI 2D as I am researching how different timber frame wall constructions perform in the Irish climate as part of my final year dissertation.
So the main graphs I am looking at are Moisture content in the studs and the RH graphs. Are there any documents with examples of timber frame analyses in WUFI2D?
Also I assume that as with WUFI Pro a moisture source of 1% of the driving rain must be placed behind weather barrier in compliance with ASHRAE 160?
I have performed all my calculations with Air change sources in my ventilated cavity and moisture sources in the outer 10mm of my stud/insulation area, is this correct?
Any advice would be great. I am just hoping that my calculations have been carried out correctly so I can draw an accurate conclusion.
Thanks guys,
Lee Corcoran
Timber Frame in WUFI 2d
Dear Lee,
everything sounds to be OK. The rain water leakage behind the weather barrier makes not so much sense - but if it worsk it provides a double safety margin
To evalute the wood moisture you should use thicknesses of the would of at least 5 or 10 mm - not single grid elements.
best reagards
best reagards
