Hello everyone,
i'm in trouble with wufi 2D 3.3 because the calculation does not start when i hit the "start" button in the processing chapter.
The software gives me a error which i don't understand. I'm still beginner with the wufi use.
the message is the following:
forrtl: severe (172): Program Exception - exception code = 0x2b4 (692)
Could anybody help us to find out why i get this error? I checked all the geometry, materials and surface/climate chapters but i don't see what goes wrong...
Thanks for your help,
Best Regards
Running Error
I guess you are on an Athlon 64.
Have you got a 64bit Version of MSWindows? If yes you should use the 64bit binary located in sub directory "x64" of your installation folder. In WUFI2D open "Options->Settings->File" and press the button right to the textfield [...]. Navigate to "IBP-Software/WUFI2D-3/x64", select w2d_flow.exe and confirm.
If not please send me an email.
Veit
Veit
I have the same error however I have a 32bit of windows.
When I tried to change to the "IBP-Software/WUFI2D-3/x64" and ran the process i get a warning that saying "the parameters are incorrect".
I have gone through all the different options I could think of and have followed the WUFI 2D Calculation Example Step by Step.
Hopefully someone can help,
Thank you
Thank you
this can happen with certain kinds of AMD-processors. Try to download this Kernel:
http://153.96.181.7/uploads/w2d_flow-ia32.zip
