Material Change after save
Rasava
Post by Rasava »
Every time I open a file, material and boundary conditions seem to reset to their defaults. I have saved the file may times, ran simulations, and each time the same materials and boundary conditions change back to defaults. All other changes that I make save just fine. What could cause this?
veitner
Re: Material Change after save
Post by veitner »
Rasava wrote:What could cause this?
Sorry, no idea. No error message? Do you store your data local or on a network share?
Veit
Rasava
Post by Rasava »
Nope No error message, and no indication of why this is happening. Everything is currently saving to the default location, which I am not 100% sure where it is located. The worst part is that even if I don't close the program for it to lose the information. If I switch between 2 projects it will do the same thing. It also loses all of the 1D information/graphs, and the only way to retrieve them is to reapply materials, redefine boundary conditions, and rerun the full simulation over again.
veitner
Post by veitner »
What version of windows are you using?
Could you try the "set as default" option? This will copy the content of your working directory to the program folder sub folder "default" (will probably not work with Windows7 - writeprotection/virtualization). At startup WUFI2D copies the content of that folder back to the working directory.
Veit
