I'm using WUFI 2D 3.2.1 and I have problems trying to export text results. I know how to export data from WUFI Graph, but I would like to create a profile of the wall.
I have found on this forum this suggestion (see below), but when I right-click on the image "extract->initial conditions" doesn't exist.
How can I export this matrix you are dealing with in this answer?
Thank you very much
Michela
there is at the moment no easy posibility to generate a profile out of the 2d calculation.
But there is a kind of tricky way:
You can extract the data for all grid elements for one time step. Open WufiMotion and go to the time step and value window you need. Then rightclick -> extract -> initial conditions. You will get a data matrix with a mean value for every grid element in a text file.
Out of this file you can try to find the right row or column and plot it. The according distance values (for x or y) you can find in the file called input.dat
Export text data
Re: Export text data
Dear Michela,
to export the initial conditions you have to open your results using the
result viewer "WUFI2DMotion". Therein you can right click the
"temperature-" "humidity-" or "water content-graph" to export the data.
The resulting text file contains 3 header lines (number of elements in
x- and y-direction (nx and ny) followed by the x- and y-grid) and a nx
by ny matrix.
Happy new year
by ny matrix.
Happy new year
