User-defined Materials - Material Property Values not saving into local database
Posted: Fri Nov 27, 2026 9:23 am -1100
Hi there,
I am currently a graduate student and am on a 6-month student license. This is my first time using WUFI Pro 7, I've mainly used WUFI Pro 6, and this is the first time where I've experienced issues with adding a user-defined material into my local database.
When I copy a material and edit it, I first hit the unlock button beside the title of the material, change the material name and properties as needed, then click "paste into database". Now this has previously worked for when I've needed to add a new material into my local database but now using Pro 7 I the new material I've pasted into my database only has a new title, all the property values I changed do not get saved and instead the original values of whatever material I select are saved under the new name I created.
I can't find anywhere online stating that the student (non-commercial use only) license no longer has access to this feature so I'm turning to the forum for support.
Any guidance would be much appreciated.
Best,
Kevin Cai
Best,
Kevin Cai
