Can HygroApprox estimate the capillary range of clay bricks?
Mikaeltm
Post by Mikaeltm »
I have experimentally determined the moisture storage function of several clay bricks in the hygroscopic range up to 96% RH, as well as the effective saturation moisture content at 100% RH.
However, I am missing data for the capillary range between 96% and 100% RH. Would HygroApprox be suitable for estimating this missing part of the moisture storage function? If so, which input parameters would you recommend using for clay bricks?
Thank you for any advice!
