AIRAH DA07 Indoor Climate
Posted: Mon Jul 21, 2025 3:12 pm -1100
by seed
I'm new to WUFI Pro and planning to use it for studying the possibility of mould growth in unconditioned, wet areas (toilets, laundry etc.). With the new WUFI Pro 7, the indoor climate can be adjusted according to 'AIRAH DA07'. With this option, is it possible to set the indoor conditions to be unconditioned, ventilated, and with a fluctuating moisture load? It seems like I can only set an air conditioning mode with setpoints and a constant moisture generation rate.
Thank you in advance for your advice.
