I am using WUFI Plus to create a model of an apartment with two floors above ground and I have some doubts about the inclusion of linear thermal bridges.
For example, in the case of the thermal bridge referred to a beam, what would be the length required by the software? That of the entire beam or should I also consider its height?
Same doubt regarding a thermal bridge referred to the wall-column junction. In that case, what would be the length of the thermal bridge to be inserted?
At last, I have an abacus of thermal bridges that allows me to calculate the psi value of a thermal bridge, both for the external and internal environment. What value would you recommend me to enter in WUFI?
