Dear WUFI Support Team,
After I installed the WUFI Plus 3.2.0.1, a warning shows that the program can not be executed on my laptop (win 10, Dell inspiration 7590, i7-9750H, 16G).
______________
The warning tells:
It's not properly installed. or you don't have sufficient permission to run it (exit code:0,2,0..."my code which is exactly same with what in the order email".)
Install program using setup software.
If program was installed properly try to run it as administrator.
Please notify FIBP about the problem.
_____________
I have tried running it as an administrator, uninstalled and reinstalled it following the Installation Guide many times, but the issue still exists.
Is there anything I can do to troubleshoot the problem?
Thank you,
QS ZHAN
