Indoor Surface Climate
is it possible to export the chosen data (temp.+rel.humidity) for indoor surfaces as csv/txt/etc.?
If not directly, I assume that someone knows a workaround for that?
Thank you.
Markus Steinwender
Thank you.
Markus Steinwender
Re: Indoor Surface Climate
Of course it is; pull-down menu ASC-Export
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
In WufiGraph for positions inside materials yes; but not for the surface condition, or am I doing something wrong?
WUFI main menu pull-down tab "Outputs"|"ASC-Export"
Or Quick Graph right mouse click on the graph
Enjoy WUFI®
Enjoy WUFI®
(main menu) tab "output" has no "asc-export" - see screenshot/attachment
- 2019-04-08 15_53_34-Greenshot.png (58.16 KiB) Viewed 2011 times
OK, I didn't know it was WUFI 2D. Right mouse click on the graph should give you the export option. You just need to create temperature and R.H. graphs at the desired positions
Enjoy WUFI®
Enjoy WUFI®
yes, this works - but not for the surface condition itself; only for the first layer of material...
I am pretty sure that the first layer is the surface condition. Fraunhofer IBP experts may confirm that.
Enjoy WUFI®
Enjoy WUFI®
OK - thank you very much. I'll take that for granted for now.
Maybe, as you suggested, Fraunhofer IBP experts confirm that (?).
No, it is not possible to export the boundary conditions with WUFI Graph at the moment. The blue boarder contains no data.
