Indoor Surface Climate
msteinwender
Post by msteinwender » Sun Apr 07, 2019 8:05 pm -1100
is it possible to export the chosen data (temp.+rel.humidity) for indoor surfaces as csv/txt/etc.?
If not directly, I assume that someone knows a workaround for that?
Thank you.
Markus Steinwender
Re: Indoor Surface Climate
Post by Manfred Kehrer » Mon Apr 08, 2019 1:44 am -1100
Of course it is; pull-down menu ASC-Export
msteinwender
Post by msteinwender » Mon Apr 08, 2019 2:43 am -1100
In WufiGraph for positions inside materials yes; but not for the surface condition, or am I doing something wrong?
Post by Manfred Kehrer » Mon Apr 08, 2019 2:46 am -1100
WUFI main menu pull-down tab "Outputs"|"ASC-Export"
Or Quick Graph right mouse click on the graph
msteinwender
Post by msteinwender » Mon Apr 08, 2019 3:10 am -1100
(main menu) tab "output" has no "asc-export" - see screenshot/attachment
2019-04-08 15_53_34-Greenshot.png (58.16 KiB) Viewed 3358 times
Post by Manfred Kehrer » Mon Apr 08, 2019 3:13 am -1100
OK, I didn't know it was WUFI 2D. Right mouse click on the graph should give you the export option. You just need to create temperature and R.H. graphs at the desired positions
msteinwender
Post by msteinwender » Mon Apr 08, 2019 3:25 am -1100
yes, this works - but not for the surface condition itself; only for the first layer of material...
Post by Manfred Kehrer » Mon Apr 08, 2019 3:27 am -1100
I am pretty sure that the first layer is the surface condition. Fraunhofer IBP experts may confirm that.
msteinwender
Post by msteinwender » Mon Apr 08, 2019 6:52 pm -1100
OK - thank you very much. I'll take that for granted for now.
Maybe, as you suggested, Fraunhofer IBP experts confirm that (?).
Post by Christian Bludau » Mon Apr 08, 2019 10:01 pm -1100
No, it is not possible to export the boundary conditions with WUFI Graph at the moment. The blue boarder contains no data.
