I've been using WUFI Pro 6 with the ASHRAE 160 internal climate conditions, which allow to assess hourly internal T and RH depending on building use, size, occupancy and ventilation rate. WUFI uses ASHRAE 160 "intermediate method" (see 4.3.2 paragraph in the standard), which is a great way to assess average internal conditions inside a building.
I need to simulate internal conditions (specifically, RH), inside specific rooms, e.g. bathrooms. Do you know of any standard that would allow you to calculate typical design conditions in specific rooms by room use?
Thank you,
Enrico
