hi
in WUFI plus how can i find the amount of the total water content in the roof?(like WUFI)
Tnx
total water content
antretterf
water content in layers
You can export the water content in layers by checking the box "retain calculation results" in the "Report: Data & Results" folder in the component dialog previous to the calculation. After the simulation is finished, all temperature, relative humidity and water content results in an hourly time step for every discretization grid point is available in the "Export" section.
I did what exactly you said and i can find those graphs for roof but as soon as my simulation calculation finished i received this error:
Unhandled exception has occurred in your application.if you click continue the application will ignore this error and attempt to continue.if you click Quit the application will close immediately .
parameter is not valid.
for you information i just tried the example file which IBP provided to me.
so i want to know that is it normal or not? as i mentioned i can get results(graphs,film) for that component even with that error
