Effect of Air Tightness
Could anyone tell me if heat and moisture transfer rates are affected by selecting different air tightness values
Re: Effect of Air Tightness
The surface transfer is not affected at interior and exterior surface...
The moisture in the assembly normally is slightly increased (it's handled as a moisture source) and following the diffusion transport from inside slightly reduced due to smaller gradients, and to the outside increased due to bigger gradients.
