using WUFI-Corr to assess corrosion in wood fasteners
All about WUFI post-processing modules and add-ons
Axelarris
Post by Axelarris » Mon Apr 23, 2018 10:38 am -1100
If I wanted to use WUFI-Corr to estimate corrosion potential of fasteners in wood construction (eg. plywood nailing), what "binder type" should I use?
The results seem to be heavily dependent on this variable, so I understand that the results for wood would be different, but is there a binder type currently available in WUFI-Corr that approximates the results for wood construction?
Re: using WUFI-Corr to assess corrosion in wood fasteners
Post by Daniel » Mon Jun 04, 2018 6:28 am -1100
Currently we have no "binder specification" for wooden materials.
Samuel Zelinka did some investigations on that topic and we wanted to extend and implement the data - but unfortunately couldn't get funding for the required additional tests...
best regards
Dr. Daniel Zirkelbach, IBP Holzkirchen
Axelarris
Post by Axelarris » Mon Jun 04, 2018 1:42 pm -1100
I really hope you can get the funding for this soon. Seems like the most application use of WUFI-Corr for residential and light-commercial in cold climates.
good luck!
