What is included for climate data?
All about WUFI Passive
woodenrings
Post by woodenrings » Thu Nov 26, 2020 10:17 am -1100
I have installed 3.2.0.1 and selected a location from the map database and expected to see all fields filled out, including those on the climate tab but only a couple fields on the Localization tab are filled in. (5 parameters, all ground info, no space conditioning data)
What is supposed to be included with this database? Am I required to purchase a PHIUS membership to get assess to the data above on top of my purchase of WUFI Passive Pro?
woodenrings
Re: What is included for climate data?
Post by woodenrings » Wed Dec 16, 2020 2:23 am -1100
For those following, the climate data found on the climate tab doesn't seem to be included with WUFI Passive. I was able to import data into the climate database and the pins show up as yellow. This is significant as the training videos show a similar pin color for locations with climate data (but likely indicated imported data) vs locations which are grey (default).
