Problem with vertical subdivisions in WUFI Passive Manual Example
All about WUFI Passive
russ@goodshacks
Post by russ@goodshacks » Tue Jul 21, 2015 12:38 pm -1100
I'm working through the Example Case in the WUFI Passive 3.0 Manual. When I get to the vertical subdivision of a layer to use for exchange material (page 146) I find that I cannot create subdivisions that match the example. When I enter the vertical subdivisions of .04 and .36 meters the vertical total should adjust to .40 meters, but it stays at 1 meter and creates a third subdivision of .60 meters that I can't delete. Any help would be appreciated.
Thanks,
-Russ
Re: Problem with vertical subdivisions in WUFI Passive Manual Example
Post by mpazold » Thu Jul 23, 2015 9:08 pm -1100
Hi Russ,
make sure that no other layer has vertical subdivision entries. The vertical and horizontal subdivisions are allways regarded from the layer with the biggest sum for the entire assembly.
So i think you have entered 1 meter in another layer vertical subdivision, then the remaining .6 meters are added automatically.
hope this helps, Matthias
russ@goodshacks
Post by russ@goodshacks » Wed Aug 05, 2015 6:03 am -1100
Thank you. Your suggestion worked. Much appreciated.
