Clear Calculations
FBabineau
Clear Calculations
Post by FBabineau »
I have a model file with several cases that I need to share. However, I do not want to share the simulation results. How can I save or export the project to a *.W6P file that just has the model parameters without the results? I already tried making small changes to the model and saving under a different file name, but the "Quick Graph" data are all still visible and the file size is still huge (>200MB).
Re: Clear Calculations
Hi FBabineau,
please go to
Options -> Result Data
and remove the check marks from those result types you do not wish to save (in your case, all of them). Then save the project file again.
