WUFI
Forum for the WUFI Software family
We are pleased to announce the release of WUFI® 2D 4.0
To upgrade sign in to our online shop
It is currently Sun Jul 22, 2018 8:33 pm -1100
Post new topic  Reply to topic  [ 4 posts ]
Author Message
 Post subject: Wufi Plus Plugin into Sketchup not working
PostPosted: Mon Feb 17, 2014 11:36 am -1100
Offline
I installed a wufi plus version 2.5.3 and sketchup version 8. I followed every single step in the web (http://www.wufi-wiki.com/mediawiki/inde ... :Sketch-Up) but the plugin installation failed. The message that always pop up is " plugin could not be installed". Is there any other way to install the plugin or any solution regarding my problem is a great help for me.
Kv.
Jose
Top
 Post subject: Re: Wufi Plus Plugin into Sketchup not working
PostPosted: Mon Feb 17, 2014 11:43 pm -1100
Offline
Hi Jose,
in WUFI Plus Version 2.5.3.0 two essential files are not installed properly, to activate the sketchup plugin.
I've send you those two files per e-mail, please copy them into your wufiplus folder (beside the wufiplus.exe) and try to install the plugin following the steps again. There is no other way to install the plugin at the moment.
Matthias
Top
PostPosted: Tue Feb 18, 2014 1:38 am -1100
Offline
Hi Matthias,
I copied the two other files (DraftManualWUFIPlus.pdf and WUFI-DB.exe) from the Wufi_plus_2_5_3 that you sent me to the location folder where I installed the Wufi Plus. I follow installation as per instruction but unfortunately problem still the same.. I even try to re-installed Wufi Plus and Sketchup 8 and deactivate the antivirus, but plugin installation still failed. I really don't know how to figure this out. By the way I'm using 32 bits windows vista. Hope there is a solution regarding my concern.
Kv
Jose
Top
PostPosted: Tue Feb 18, 2014 11:57 pm -1100
Offline
I think, finally it works by copy the two files: SKP_WUFIplus_PlugIn.rb and SKPwufi.exe in the next Release this problem will be fixed.
best regards
matthias
Top
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Imprint
Standard Business Terms/ Allgemeine Geschäftsbedingungen
Powered by phpBB® Forum Software © phpBB Limited
