Post-Processing
Post-Processing
Hello.
I've been wondering if there is a possibility to transfer ALL the output data into an Excel/Text file otherwise than having to "create" a curve under WUFIGraph and export it in txt format.
The problem being that WUFIGraph becomes VERY slow after some curves which each take time to calculate... If I could just select the data but avoid the graph creation that would accelerate post-processing analysis.
I tried to read the wfd directly, but it's coded in an unknown format (or so it seems).
Any ideas on this?
Thank you!
Manexi
Any ideas on this?
Thank you!
Manexi
wufi2dfile.f90
! File: wufi2dfile.f90
! Created on September 21, 2006, 1:41 PM
MODULE WUFI2DFILE
implicit none
INTEGER,PARAMETER :: NDATA=8
TYPE HEADER
INTEGER(2) :: BYTEORDER1
INTEGER(2) :: BYTEORDER2
INTEGER(1) :: L
CHARACTER(9) :: INFO
INTEGER(2) :: VERSION
INTEGER(4) :: GIPOS,OPTPOS,RGBPOS,CIPOS,GRIDPOS,DATAPOS
INTEGER :: NCTS
END TYPE HEADER
! TYPE GENERALINFO
!.....RESERVED FOR FURTHER USE
! END TYPE GENERALINFO
TYPE MINMAX
REAL(4) MIN, MAX
END TYPE MINMAX
TYPE OPTION
TYPE (MINMAX) UB(NDATA)
END TYPE OPTION
TYPE TRGB
INTEGER(1), DIMENSION(16) :: R,G,B
END TYPE TRGB
TYPE CALCINFO_BOOL
LOGICAL(1) HEAT,CAP,HEATOFVAP,HEATOFFUS,EXACT,CONV,LIST,HMEAN,CORR
END TYPE CALCINFO_BOOL
TYPE CALCINFO
TYPE (CALCINFO_BOOL) BOOL
END TYPE CALCINFO
TYPE TAB
REAL(4) :: X,Y
END TYPE TAB
TYPE TABD
REAL(4) :: X,Y,DY
END TYPE TABD
TYPE TCOLOR
INTEGER(2) :: R,G,B
END TYPE TCOLOR
TYPE MATERIAL
CHARACTER(50) :: QBMAT
LOGICAL :: LADIAB
TYPE(TCOLOR) :: COLOR
INTEGER(2) :: NLMBX,NLMBY,NMYX,NMYY, &
&NFKSX,NFKSY,NFKRX,NFKRY,NSOR
REAL(4) :: RHO,CAP,DLAMX,DLAMY,ZULAM,TETAI, &
&POR,RHI,WF,W95,WMAX
REAL :: GAMMAX,GAMMAY
TYPE(TAB),DIMENSION(:),ALLOCATABLE :: BLTABX,BLTABY,BMYTABX,BMYTABY, &
&FKTABSX,FKTABSY,FKTABRX,FKTABRY
TYPE(TABD),DIMENSION(:),ALLOCATABLE :: SORTAB
LOGICAL :: LLMAUTO,LSOR,NOFI,NOTRANS,LWCINI
CHARACTER(90) :: FVNAME
!fixed values
REAL(4) :: FVRH,FVTETA
END TYPE MATERIAL
CONTAINS
SUBROUTINE HEADOUT(OBIN,FBPOS,MIMAPOS,NCTSPOS,HEAD,DATAOUT,STARTDATE,MIMA,X,Y,NI,NJ,nks,materials,matcls)
INTEGER,INTENT(INOUT) :: FBPOS,MIMAPOS,NCTSPOS
INTEGER, INTENT(IN) :: OBIN,ni,nj,nks
TYPE(HEADER), INTENT(INOUT) :: HEAD
LOGICAL(2),DIMENSION(NDATA),INTENT(IN) :: DATAOUT
TYPE(MINMAX),DIMENSION(NDATA),INTENT(IN) :: MIMA
CHARACTER(16),INTENT(IN) :: STARTDATE
REAL,DIMENSION(NI),INTENT(IN) :: x
REAL,DIMENSION(NJ),INTENT(IN) :: y
INTEGER,DIMENSION(ni*nj),INTENT(IN) :: MATCLS
TYPE(MATERIAL),DIMENSION(:),INTENT(IN) :: MATERIALS
INTEGER(4) NXX,NYY
REAL(4), DIMENSION(:),ALLOCATABLE:: XX
REAL(4), DIMENSION(:),ALLOCATABLE:: YY
INTEGER :: NIJ
TYPE (OPTION) :: OPT
TYPE (TRGB) :: RGB
TYPE (CALCINFO) ::CI
INTEGER :: I,J
INTEGER(1) :: L=16
!needed for paralellisation
INTEGER(2),DIMENSION(:),ALLOCATABLE :: tmp
NIJ = NI*NJ
ALLOCATE(XX(NI))
ALLOCATE(YY(NJ))
ALLOCATE(tmp(NIJ))
HEAD%L=9
HEAD%INFO='$w2dflow$'
HEAD%VERSION=4
HEAD%BYTEORDER1=65226
HEAD%BYTEORDER2=48875
CI%BOOL%HEAT=.TRUE.
CI%BOOL%CAP=.FALSE.
CI%BOOL%HEATOFVAP=.TRUE.
! HEAD%GIPOS=SIZEOF(HEAD)
HEAD%OPTPOS=SIZEOF(HEAD)
HEAD%RGBPOS=HEAD%OPTPOS+SIZEOF(OPT)
HEAD%CIPOS=HEAD%RGBPOS+SIZEOF(RGB)
HEAD%GRIDPOS=HEAD%CIPOS+SIZEOF(CI)
! HEAD%DATAPOS=HEAD%GRIDPOS+SIZEOF(GD)+2*NI*NJ+
! * NKS*SIZEOF(MAT(1)) !UNABLE TO CALCULATE IT THE
! WRITE IT AGAIN AT THE END OF THIS PROCEDURE
NCTSPOS=1+SIZEOF(HEAD)-SIZEOF(HEAD%NCTS)
FBPOS=1
WRITE(OBIN,POS=FBPOS) HEAD
FBPOS=FBPOS+SIZEOF(HEAD)
WRITE(OBIN,POS=FBPOS) OPT
FBPOS=FBPOS+SIZEOF(OPT)
WRITE(OBIN,POS=FBPOS) L
FBPOS=FBPOS+SIZEOF(L)
WRITE(OBIN,POS=FBPOS) STARTDATE
FBPOS=FBPOS+SIZEOF(STARTDATE)
WRITE(OBIN,POS=FBPOS) (DATAOUT(I), I=1,NDATA)
FBPOS=FBPOS+SIZEOF(DATAOUT(1))*NDATA
WRITE(OBIN,POS=FBPOS) CI%BOOL
FBPOS=FBPOS+SIZEOF(CI%BOOL)
MIMAPOS=FBPOS
WRITE(OBIN,POS=FBPOS) MIMA
FBPOS=FBPOS+SIZEOF(MIMA)
NXX=NI
NYY=NJ
XX(1:NI)=X(1:NI)
YY(1:NJ)=Y(1:NJ)
WRITE(OBIN,POS=FBPOS) NXX,NYY,XX(1:NI),YY(1:NJ)
FBPOS=FBPOS+SIZEOF(NXX)+SIZEOF(NYY) &
& +SIZEOF(XX(1))*NI+SIZEOF(YY(1))*NJ
!.....MATERIALCLASSIFICATION
WRITE(OBIN,POS=FBPOS) NKS
FBPOS=FBPOS+SIZEOF(NKS)
! WRITE(OBIN,POS=FBPOS) ((MATCLS(I,J),J=1,NJ),I=1,NI)
tmp(1:NIJ) = MATCLS(1:NIJ)
WRITE(OBIN,POS=FBPOS) tmp(1:NIJ)!MATCLS(1:NIJ)
FBPOS=FBPOS+SIZEOF(tmp(1))*NI*NJ!SIZEOF(MATCLS(1))*NI*NJ
CALL PRINT_MATERIALS(OBIN,FBPOS,MATERIALS)
!ZERO BASED!!!
HEAD%DATAPOS=FBPOS-1
WRITE(OBIN,POS=1) HEAD
DEALLOCATE(XX)
DEALLOCATE(YY)
DEALLOCATE(tmp)
RETURN
END SUBROUTINE HEADOUT
SUBROUTINE PRINT_MATERIALS(OBIN,FBPOS,MATERIALS)
INTEGER :: N,K,tt
TYPE(TAB) :: mt2
TYPE(TABD) :: mt3
INTEGER :: tab2s
INTEGER :: tab3s
TYPE(MATERIAL) :: M
!for g95
tab2s=sizeof(mt2)
tab3s=sizeof(mt3)
DO K=1,SIZE(MATERIALS)
M = MATERIALS(K)
WRITE(OBIN,POS=FBPOS) M%QBMAT
FBPOS=FBPOS+SIZEOF(M%QBMAT)
WRITE(OBIN,POS=FBPOS) M%COLOR
FBPOS=FBPOS+SIZEOF(M%COLOR)
WRITE(OBIN,POS=FBPOS) M%NLMBX
FBPOS=FBPOS+SIZEOF(M%NLMBX)
WRITE(OBIN,POS=FBPOS) M%NLMBY
FBPOS=FBPOS+SIZEOF(M%NLMBY)
WRITE(OBIN,POS=FBPOS) M%NMYX
FBPOS=FBPOS+SIZEOF(M%NMYX)
WRITE(OBIN,POS=FBPOS) M%NMYY
FBPOS=FBPOS+SIZEOF(M%NMYY)
WRITE(OBIN,POS=FBPOS) M%NFKSX
FBPOS=FBPOS+SIZEOF(M%NFKSX)
WRITE(OBIN,POS=FBPOS) M%NFKSY
FBPOS=FBPOS+SIZEOF(M%NFKSY)
WRITE(OBIN,POS=FBPOS) M%NFKRX
FBPOS=FBPOS+SIZEOF(M%NFKRX)
WRITE(OBIN,POS=FBPOS) M%NFKRY
FBPOS=FBPOS+SIZEOF(M%NFKRY)
WRITE(OBIN,POS=FBPOS) M%NSOR
FBPOS=FBPOS+SIZEOF(M%NSOR)
WRITE(OBIN,POS=FBPOS) M%RHO
FBPOS=FBPOS+SIZEOF(M%RHO)
WRITE(OBIN,POS=FBPOS) M%W95
FBPOS=FBPOS+SIZEOF(M%W95)
WRITE(OBIN,POS=FBPOS) M%CAP
FBPOS=FBPOS+SIZEOF(M%CAP)
WRITE(OBIN,POS=FBPOS) M%DLAMX
FBPOS=FBPOS+SIZEOF(M%DLAMX)
WRITE(OBIN,POS=FBPOS) M%DLAMY
FBPOS=FBPOS+SIZEOF(M%DLAMY)
WRITE(OBIN,POS=FBPOS) M%ZULAM
FBPOS=FBPOS+SIZEOF(M%ZULAM)
WRITE(OBIN,POS=FBPOS) M%POR
FBPOS=FBPOS+SIZEOF(M%POR)
WRITE(OBIN,POS=FBPOS) M%WF
FBPOS=FBPOS+SIZEOF(M%WF)
WRITE(OBIN,POS=FBPOS) M%WMAX
FBPOS=FBPOS+SIZEOF(M%WMAX)
WRITE(OBIN,POS=FBPOS) M%TETAI
FBPOS=FBPOS+SIZEOF(M%TETAI)
WRITE(OBIN,POS=FBPOS) M%RHI
FBPOS=FBPOS+SIZEOF(M%RHI)
WRITE(OBIN,POS=FBPOS) (M%BLTABX(N),N=1,M%NLMBX)
FBPOS=FBPOS+M%NLMBX*tab2s
WRITE(OBIN,POS=FBPOS) (M%BLTABY(N),N=1,M%NLMBY)
FBPOS=FBPOS+M%NLMBY*tab2s
WRITE(OBIN,POS=FBPOS) (M%BMYTABX(N),N=1,M%NMYX)
FBPOS=FBPOS+M%NMYX*tab2s
WRITE(OBIN,POS=FBPOS) (M%BMYTABY(N),N=1,M%NMYY)
FBPOS=FBPOS+M%NMYY*tab2s
WRITE(OBIN,POS=FBPOS) (M%FKTABSX(N),N=1,M%NFKSX)
FBPOS=FBPOS+M%NFKSX*tab2s
WRITE(OBIN,POS=FBPOS) (M%FKTABSY(N),N=1,M%NFKSY)
FBPOS=FBPOS+M%NFKSY*tab2s
WRITE(OBIN,POS=FBPOS) (M%FKTABRX(N),N=1,M%NFKRX)
FBPOS=FBPOS+M%NFKRX*tab2s
WRITE(OBIN,POS=FBPOS) (M%FKTABRY(N),N=1,M%NFKRY)
FBPOS=FBPOS+M%NFKRY*tab2s
WRITE(OBIN,POS=FBPOS) (M%SORTAB(N),N=1,M%NSOR)
FBPOS=FBPOS+M%NSOR*tab3s
END DO
END SUBROUTINE PRINT_MATERIALS
SUBROUTINE PRINTVEC(OBIN,FBPOS,DATAOUT,v11,v12,v21,v22,v31,v32,v41,v42,MIMA,NI,NJ)
INTEGER,INTENT(IN) :: OBIN,NI,NJ
REAL,DIMENSION(ni*nj) :: v11,v12,v21,v22,v31,v32,v41,v42
TYPE(MINMAX), DIMENSION(NDATA),INTENT(INOUT) :: MIMA
INTEGER I,J,ID,II,IJ,VECSIZE
REAL(4), DIMENSION(:,:),ALLOCATABLE :: AMO,FI
REAL(4) :: SX,SY
REAL(4) :: PI18,MIN,MAX
DATA PI18/57.2957795131/
ALLOCATE(AMO(NJ,NI))
ALLOCATE(FI(NJ,NI))
VECSIZE=SIZEOF(AMO(1,1))*NI*NJ
DO 100 ID=5,8
IF (.NOT.DATAOUT(ID)) GOTO 100
!PRINT FLUK
IF (ID.EQ.5) THEN
AMO = RESHAPE(v11,(/NJ,NI/))
FI = RESHAPE(v12,(/NJ,NI/))
!PRINT FLUD
ELSE IF (ID.EQ.6) THEN
AMO = RESHAPE(v21,(/NJ,NI/))
FI = RESHAPE(v22,(/NJ,NI/))
!PRINT FLUT
ELSE IF (ID.EQ.7) THEN
AMO = RESHAPE(v31,(/NJ,NI/))
FI = RESHAPE(v32,(/NJ,NI/))
!PRINT VXY
ELSE IF (ID.EQ.8) THEN
AMO = RESHAPE(v41,(/NJ,NI/))
FI = RESHAPE(v42,(/NJ,NI/))
END IF
MIN=MINVAL(AMO(2:NJ-1,2:NI-1))
IF (MIN.LT.MIMA(ID)%MIN) MIMA(ID)%MIN=MIN
MAX=MAXVAL(AMO(2:NJ-1,2:NI-1))
IF (MAX.GT.MIMA(ID)%MAX) MIMA(ID)%MAX=MAX
WRITE(OBIN,POS=FBPOS) ((AMO(J,I),J=1,NJ),I=1,NI)
FBPOS=FBPOS+VECSIZE
WRITE(OBIN,POS=FBPOS) ((FI(J,I),J=1,NJ),I=1,NI)
FBPOS=FBPOS+VECSIZE
100 END DO
DEALLOCATE(AMO)
DEALLOCATE(FI)
RETURN
END SUBROUTINE PRINTVEC
SUBROUTINE PRINTSCA(OBIN,FBPOS,DATAOUT,RH,WC,TETA,PD,MIMA,NI,NJ)
REAL,DIMENSION(ni*nj) :: rh,wc,teta,pd
INTEGER I,J,ID,SCSIZE
REAL(4), DIMENSION(:,:),ALLOCATABLE :: FI
REAL(4) MIN, MAX
ALLOCATE(FI(NJ,NI))
SCSIZE=SIZEOF(FI(1,1))*NI*NJ
DO 10 ID=1,4
!PRINT WC
IF (ID.EQ.1) THEN
FI=RESHAPE(WC,(/NJ,NI/))
!PRINT RH
ELSE IF (ID.EQ.2) THEN
FI=RESHAPE(RH,(/NJ,NI/))
!PRINT TETA
ELSE IF (ID.EQ.3) THEN
FI=RESHAPE(TETA,(/NJ,NI/))
!PRINT PD
ELSE IF (ID.EQ.4) THEN
FI=RESHAPE(PD,(/NJ,NI/))
END IF
MIN=MINVAL(FI(1:NJ,1:NI))
MAX=MAXVAL(FI(1:NJ,1:NI))
FBPOS=FBPOS+SCSIZE
10 END DO
DEALLOCATE(FI)
RETURN
END SUBROUTINE PRINTSCA
SUBROUTINE PRINTBIN(OBIN,FBPOS,MIMAPOS,NCTSPOS,TIME,DATAOUT,RH,WC,TETA,PD,v11,v12,v21,v22,v31,v32,v41,v42,MIMA,NI,NJ,NT)
INTEGER,INTENT(IN) :: OBIN,NI,NJ,NT
REAL,DIMENSION(ni*nj) :: RH,WC,TETA,PD,v11,v12,v21,v22,v31,v32,v41,v42
REAL(8),INTENT(IN) :: TIME
TYPE(MINMAX),DIMENSION(NDATA),INTENT(INOUT) :: MIMA
WRITE(OBIN,POS=FBPOS) TIME
FBPOS=FBPOS+SIZEOF(TIME)
CALL PRINTSCA(OBIN,FBPOS,DATAOUT,RH,WC,TETA,PD,MIMA,NI,NJ)
CALL PRINTVEC(OBIN,FBPOS,DATAOUT,v11,v12,v21,v22,v31,v32,v41,v42,MIMA,NI,NJ)
WRITE(OBIN,POS=MIMAPOS) MIMA
WRITE(OBIN,POS=NCTSPOS) NT
RETURN
END SUBROUTINE PRINTBIN
! READ
SUBROUTINE HEADIN(OBIN,HEAD,DATAOUT,STARTDATE,MIMA,X,Y,NI,NJ,nks,materials,matcls,FBPOS)
INTEGER,INTENT(INOUT) :: ni,nj,nks,FBPOS
LOGICAL(2),DIMENSION(NDATA),INTENT(INOUT) :: DATAOUT
CHARACTER(16),INTENT(INOUT) :: STARTDATE
REAL,DIMENSION(:),ALLOCATABLE,INTENT(INOUT) :: x
REAL,DIMENSION(:),ALLOCATABLE,INTENT(INOUT) :: y
INTEGER,DIMENSION(:),ALLOCATABLE,INTENT(INOUT) :: MATCLS
TYPE(MATERIAL),DIMENSION(:),ALLOCATABLE,INTENT(INOUT) :: MATERIALS
INTEGER(4) NXX,NYY
INTEGER :: NIJ
TYPE (TRGB) :: RGB
INTEGER :: I,J
INTEGER(1) :: L=16
READ(OBIN) HEAD
READ(OBIN) OPT
READ(OBIN) L
READ(OBIN) STARTDATE
READ(OBIN) DATAOUT
READ(OBIN) CI%BOOL
READ(OBIN) MIMA
READ(OBIN) NXX,NYY
NI=NXX
NJ=NYY
NIJ = NI*NJ
ALLOCATE(XX(NI))
ALLOCATE(YY(NJ))
ALLOCATE(tmp(NIJ))
READ(OBIN) XX(1:NI),YY(1:NJ)
allocate(x(ni))
allocate(y(nj))
x(1:NI)=XX(1:NI)
y(1:NJ)=YY(1:NJ)
READ(OBIN) NKS
READ(OBIN) tmp(1:NIJ)!MATCLS(1:NIJ)
allocate(matcls(nij))
MATCLS = tmp
allocate(MATERIALS(NKS))
CALL READ_MATERIALS(OBIN,NKS,MATERIALS,FBPOS)
DEALLOCATE(XX)
DEALLOCATE(YY)
DEALLOCATE(tmp)
RETURN
END SUBROUTINE HEADIN
SUBROUTINE READ_MATERIALS(OBIN,NKS,MATERIALS,FBPOS)
INTEGER, INTENT(IN) :: OBIN,NKS
TYPE(MATERIAL),DIMENSION(:),INTENT(INOUT) :: MATERIALS
INTEGER, INTENT(INOUT) :: FBPOS
INTEGER :: N,K,tt
TYPE(TAB) :: mt2
TYPE(TABD) :: mt3
INTEGER :: tab2s
INTEGER :: tab3s
TYPE(MATERIAL) :: M
!for g95
tab2s=sizeof(mt2)
tab3s=sizeof(mt3)
DO K=1,NKS
READ(OBIN) MATERIALS(K)%QBMAT
READ(OBIN) MATERIALS(K)%COLOR
READ(OBIN) MATERIALS(K)%NLMBX
READ(OBIN) MATERIALS(K)%NLMBY
READ(OBIN) MATERIALS(K)%NMYX
READ(OBIN) MATERIALS(K)%NMYY
READ(OBIN) MATERIALS(K)%NFKSX
READ(OBIN) MATERIALS(K)%NFKSY
READ(OBIN) MATERIALS(K)%NFKRX
READ(OBIN) MATERIALS(K)%NFKRY
READ(OBIN) MATERIALS(K)%NSOR
READ(OBIN) MATERIALS(K)%RHO
READ(OBIN) MATERIALS(K)%W95
READ(OBIN) MATERIALS(K)%CAP
READ(OBIN) MATERIALS(K)%DLAMX
READ(OBIN) MATERIALS(K)%DLAMY
READ(OBIN) MATERIALS(K)%ZULAM
READ(OBIN) MATERIALS(K)%POR
READ(OBIN) MATERIALS(K)%WF
READ(OBIN) MATERIALS(K)%WMAX
READ(OBIN) MATERIALS(K)%TETAI
READ(OBIN) MATERIALS(K)%RHI
allocate(MATERIALS(K)%BLTABX(MATERIALS(K)%NLMBX))
allocate(MATERIALS(K)%BLTABY(MATERIALS(K)%NLMBY))
allocate(MATERIALS(K)%BMYTABX(MATERIALS(K)%NMYX))
allocate(MATERIALS(K)%BMYTABY(MATERIALS(K)%NMYY))
allocate(MATERIALS(K)%FKTABSX(MATERIALS(K)%NFKSX))
allocate(MATERIALS(K)%FKTABSY(MATERIALS(K)%NFKSY))
allocate(MATERIALS(K)%FKTABRX(MATERIALS(K)%NFKRX))
allocate(MATERIALS(K)%FKTABRY(MATERIALS(K)%NFKRY))
allocate(MATERIALS(K)%SORTAB(MATERIALS(K)%NSOR))
READ(OBIN) (MATERIALS(K)%BLTABX(N),N=1,MATERIALS(K)%NLMBX)
READ(OBIN) (MATERIALS(K)%BLTABY(N),N=1,MATERIALS(K)%NLMBY)
READ(OBIN) (MATERIALS(K)%BMYTABX(N),N=1,MATERIALS(K)%NMYX)
READ(OBIN) (MATERIALS(K)%BMYTABY(N),N=1,MATERIALS(K)%NMYY)
READ(OBIN) (MATERIALS(K)%FKTABSX(N),N=1,MATERIALS(K)%NFKSX)
READ(OBIN) (MATERIALS(K)%FKTABSY(N),N=1,MATERIALS(K)%NFKSY)
READ(OBIN) (MATERIALS(K)%FKTABRX(N),N=1,MATERIALS(K)%NFKRX)
READ(OBIN) (MATERIALS(K)%FKTABRY(N),N=1,MATERIALS(K)%NFKRY)
READ(OBIN) (MATERIALS(K)%SORTAB(N),N=1,MATERIALS(K)%NSOR)
END DO
END SUBROUTINE READ_MATERIALS
SUBROUTINE READSCA(OBIN,DATAOUT,RH,WC,TETA,PD,NI,NJ,FBPOS)
REAL,DIMENSION(ni*nj),INTENT(INOUT) :: rh,wc,teta,pd
ALLOCATE(FI(NJ,NI))
DO 10 ID=1,4
READ(OBIN) ((FI(J,I),J=1,NJ),I=1,NI)
!PRINT WC
IF (ID.EQ.1) THEN
WC=RESHAPE(FI,(/NJ*NI/))
!PRINT RH
RH=RESHAPE(FI,(/NJ*NI/))
!PRINT TETA
TETA=RESHAPE(FI,(/NJ*NI/))
!PRINT PD
PD=RESHAPE(FI,(/NJ*NI/))
END IF
10 END DO
DEALLOCATE(FI)
RETURN
END SUBROUTINE READSCA
SUBROUTINE READVEC(OBIN,DATAOUT,v11,v12,v21,v22,v31,v32,v41,v42,NI,NJ,FBPOS)
REAL(4) :: SX,SY
ALLOCATE(FI(NJ,NI))
DO 100 ID=5,8
READ(OBIN) ((AMO(J,I),J=1,NJ),I=1,NI)
!PRINT FLUK
IF (ID.EQ.5) THEN
v11 = RESHAPE(AMO,(/NJ*NI/))
v12 = RESHAPE(FI,(/NJ*NI/))
!PRINT FLUD
v21 = RESHAPE(AMO,(/NJ*NI/))
v22 = RESHAPE(FI,(/NJ*NI/))
!PRINT FLUT
v31 = RESHAPE(AMO,(/NJ*NI/))
v32 = RESHAPE(FI,(/NJ*NI/))
!PRINT VXY
v41 = RESHAPE(AMO,(/NJ*NI/))
v42 = RESHAPE(FI,(/NJ*NI/))
END IF
100 END DO
DEALLOCATE(AMO)
DEALLOCATE(FI)
RETURN
END SUBROUTINE READVEC
SUBROUTINE READBIN(OBIN,TIME,DATAOUT,RH,WC,TETA,PD,v11,v12,v21,v22,v31,v32,v41,v42,NI,NJ,FBPOS)
REAL,DIMENSION(ni*nj),INTENT(INOUT) :: rh,wc,teta,pd,v11,v12,v21,v22,v31,v32,v41,v42
REAL(8),INTENT(INOUT) :: TIME
READ(OBIN) TIME
CALL READSCA(OBIN,DATAOUT,RH,WC,TETA,PD,NI,NJ,FBPOS)
CALL READVEC(OBIN,DATAOUT,v11,v12,v21,v22,v31,v32,v41,v42,NI,NJ,FBPOS)
RETURN
END SUBROUTINE READBIN
END MODULE WUFI2DFILE
MODULE WUFI2DFILE
implicit none
TYPE HEADER
INTEGER(1) :: L
INTEGER :: NCTS
END TYPE HEADER
! TYPE GENERALINFO
TYPE MINMAX
REAL(4) MIN, MAX
END TYPE MINMAX
TYPE OPTION
END TYPE OPTION
TYPE TRGB
END TYPE TRGB
TYPE CALCINFO_BOOL
TYPE CALCINFO
END TYPE CALCINFO
TYPE TAB
REAL(4) :: X,Y
END TYPE TAB
TYPE TABD
REAL(4) :: X,Y,DY
END TYPE TABD
TYPE TCOLOR
INTEGER(2) :: R,G,B
END TYPE TCOLOR
TYPE MATERIAL
LOGICAL :: LADIAB
!fixed values
END TYPE MATERIAL
CONTAINS
INTEGER(4) NXX,NYY
INTEGER :: NIJ
TYPE (TRGB) :: RGB
INTEGER :: I,J
INTEGER(1) :: L=16
NIJ = NI*NJ
ALLOCATE(XX(NI))
ALLOCATE(YY(NJ))
ALLOCATE(tmp(NIJ))
HEAD%L=9
HEAD%VERSION=4
CI%BOOL%HEAT=.TRUE.
CI%BOOL%CAP=.FALSE.
FBPOS=1
MIMAPOS=FBPOS
NXX=NI
NYY=NJ
XX(1:NI)=X(1:NI)
YY(1:NJ)=Y(1:NJ)
!ZERO BASED!!!
DEALLOCATE(XX)
DEALLOCATE(YY)
DEALLOCATE(tmp)
RETURN
INTEGER :: N,K,tt
TYPE(TAB) :: mt2
TYPE(TABD) :: mt3
INTEGER :: tab2s
INTEGER :: tab3s
TYPE(MATERIAL) :: M
!for g95
tab2s=sizeof(mt2)
tab3s=sizeof(mt3)
M = MATERIALS(K)
END DO
REAL(4) :: SX,SY
ALLOCATE(FI(NJ,NI))
DO 100 ID=5,8
!PRINT FLUK
IF (ID.EQ.5) THEN
!PRINT FLUD
!PRINT FLUT
!PRINT VXY
END IF
FBPOS=FBPOS+VECSIZE
FBPOS=FBPOS+VECSIZE
100 END DO
DEALLOCATE(AMO)
DEALLOCATE(FI)
RETURN
REAL(4) MIN, MAX
ALLOCATE(FI(NJ,NI))
DO 10 ID=1,4
!PRINT WC
IF (ID.EQ.1) THEN
!PRINT RH
!PRINT TETA
!PRINT PD
END IF
FBPOS=FBPOS+SCSIZE
10 END DO
DEALLOCATE(FI)
RETURN
RETURN
! READ
INTEGER(4) NXX,NYY
INTEGER :: NIJ
TYPE (TRGB) :: RGB
INTEGER :: I,J
INTEGER(1) :: L=16
READ(OBIN) HEAD
READ(OBIN) OPT
READ(OBIN) L
READ(OBIN) DATAOUT
READ(OBIN) CI%BOOL
READ(OBIN) MIMA
READ(OBIN) NXX,NYY
NI=NXX
NJ=NYY
NIJ = NI*NJ
ALLOCATE(XX(NI))
ALLOCATE(YY(NJ))
ALLOCATE(tmp(NIJ))
allocate(x(ni))
allocate(y(nj))
x(1:NI)=XX(1:NI)
y(1:NJ)=YY(1:NJ)
READ(OBIN) NKS
MATCLS = tmp
DEALLOCATE(XX)
DEALLOCATE(YY)
DEALLOCATE(tmp)
RETURN
INTEGER :: N,K,tt
TYPE(TAB) :: mt2
TYPE(TABD) :: mt3
INTEGER :: tab2s
INTEGER :: tab3s
TYPE(MATERIAL) :: M
!for g95
tab2s=sizeof(mt2)
tab3s=sizeof(mt3)
DO K=1,NKS
END DO
ALLOCATE(FI(NJ,NI))
DO 10 ID=1,4
!PRINT WC
IF (ID.EQ.1) THEN
!PRINT RH
!PRINT TETA
!PRINT PD
END IF
10 END DO
DEALLOCATE(FI)
RETURN
REAL(4) :: SX,SY
ALLOCATE(FI(NJ,NI))
DO 100 ID=5,8
!PRINT FLUK
IF (ID.EQ.5) THEN
!PRINT FLUD
!PRINT FLUT
!PRINT VXY
END IF
100 END DO
DEALLOCATE(AMO)
DEALLOCATE(FI)
RETURN
READ(OBIN) TIME
RETURN
sample program wfddiff.f90
! File: wfddiff.f90
program wfddiff
USE WUFI2DFILE
implicit none
INTEGER :: IARGC
INTEGER :: ARGCOUNT
CHARACTER(255) :: wfd1,wfd2
INTEGER :: IBIN1=10000,IBIN2=11000,OBIN=1000,OBIN2=2000
!in
TYPE(HEADER) :: head1,head2
INTEGER :: ni1,ni2,nj1,nj2,nks1,nks2
LOGICAL(2),DIMENSION(NDATA) :: dataout1,dataout2,DATAOUTOUT
TYPE(MINMAX),DIMENSION(NDATA) :: mima1,mima2
CHARACTER(16):: startdate1,startdate2
REAL,DIMENSION(:),ALLOCATABLE :: x1,x2
REAL,DIMENSION(:),ALLOCATABLE :: y1,y2
INTEGER,DIMENSION(:),ALLOCATABLE :: matcls1,matcls2
TYPE(MATERIAL),DIMENSION(:),ALLOCATABLE :: materials1,materials2
REAL,DIMENSION(:), ALLOCATABLE :: rh1,rh2,wc1,wc2,teta1,teta2,pd1,pd2
REAL,DIMENSION(:), ALLOCATABLE :: v111,v112,v121,v122,v131,v132,v141,v142,v211,v212,v221,v222,v231,v232,v241,v242
REAL(8) :: time1,time2
character(len=32) :: fmt1
integer :: l
!out/in
INTEGER :: FBPOS,MIMAPOS,NCTSPOS,FBPOSIN1,FBPOSIN2
TYPE(MINMAX),DIMENSION(NDATA) :: mimaout
INTEGER :: i,j,count
ARGCOUNT = IARGC()
if(ARGCOUNT.ne.2) then
write(*,*) '2 arguments needed, 1st wfd file, 2nd wfd file'
stop
end if
CALL GETARG(1,wfd1)
wfd1 = TRIM(wfd1)
CALL GETARG(2,wfd2)
wfd2 = TRIM(wfd2)
OPEN(UNIT=IBIN1,FILE=wfd1,&
STATUS='OLD', FORM='UNFORMATTED',ACCESS='STREAM')
OPEN(UNIT=IBIN2,FILE=wfd2,&
OPEN(UNIT=OBIN,FILE='diff.wfd',&
STATUS='REPLACE', FORM='UNFORMATTED',ACCESS='STREAM')
OPEN(UNIT=OBIN2,FILE='diffmax.txt',STATUS='REPLACE')
FBPOSIN1 = 1
FBPOSIN2 = 1
call HEADIN(IBIN1,HEAD1,DATAOUT1,STARTDATE1,MIMA1,X1,Y1,NI1,NJ1,nks1,materials1,matcls1,FBPOSIN1)
call HEADIN(IBIN2,HEAD2,DATAOUT2,STARTDATE2,MIMA2,X2,Y2,NI2,NJ2,nks2,materials2,matcls2,FBPOSIN2)
if(ni1.ne.ni2.or.nj1.ne.nj2) then
write(*,*) 'Different size of domains'
stop
end if
do i=1,NDATA
DATAOUTOUT(i) = dataout1(i).and.dataout2(i)
end do
allocate(rh1(ni1*nj1))
allocate(wc1(ni1*nj1))
allocate(teta1(ni1*nj1))
allocate(pd1(ni1*nj1))
allocate(rh2(ni1*nj1))
allocate(wc2(ni1*nj1))
allocate(teta2(ni1*nj1))
allocate(pd2(ni1*nj1))
allocate(v111(ni1*nj1))
allocate(v112(ni1*nj1))
allocate(v121(ni1*nj1))
allocate(v122(ni1*nj1))
allocate(v131(ni1*nj1))
allocate(v132(ni1*nj1))
allocate(v141(ni1*nj1))
allocate(v142(ni1*nj1))
allocate(v211(ni1*nj1))
allocate(v212(ni1*nj1))
allocate(v221(ni1*nj1))
allocate(v222(ni1*nj1))
allocate(v231(ni1*nj1))
allocate(v232(ni1*nj1))
allocate(v241(ni1*nj1))
allocate(v242(ni1*nj1))
do i=1,NDATA
mimaout(i)%MIN = HUGE(mimaout(i)%MIN)
mimaout(i)%MAX = -HUGE(mimaout(i)%MAX)
end do
call HEADOUT(OBIN,FBPOS,MIMAPOS,NCTSPOS,HEAD1,DATAOUT1,STARTDATE1,MIMAOUT,X1,Y1,NI1,NJ1,nks1,materials1,matcls1)
write(*,fmt='(a),1x', ADVANCE='NO') 'Timestep:'
count = MIN(head1%ncts,head2%ncts)
do i=0,count
call READBIN(IBIN1,TIME1,DATAOUT1,RH1,WC1,TETA1,PD1,v111,v112,v121,v122,v131,v132,v141,v142,NI1,NJ1,FBPOSIN1)
call READBIN(IBIN2,TIME2,DATAOUT2,RH2,WC2,TETA2,PD2,v211,v212,v221,v222,v231,v232,v241,v242,NI2,NJ2,FBPOSIN2)
wc1 = wc1 - wc2
rh1 = rh1 - rh2
teta1 = teta1 - teta2
pd1 = pd1 - pd2
v111 = v111 - v211
v112 = v112 - v212
v121 = v121 - v221
v122 = v122 - v222
v131 = v131 - v231
v132 = v132 - v232
v141 = v141 - v241
v142 = v142 - v242
call PRINTBIN(OBIN,FBPOS,MIMAPOS,NCTSPOS,TIME1,DATAOUT1,RH1,WC1,TETA1,PD1,v111,v112,v121,v122,v131,v132,v141,v142,&
MIMAOUT,NI1,NJ1,i)
write(OBIN2,*) 'Timestep:',i
if(DATAOUT1(1)) write(OBIN2,5000) &
'Max(WC)',MAXVAL((wc1)), &
'Min(WC)',MINVAL((wc1)), &
'Sum(ABS(WC))',SUM(ABS(wc1))
if(DATAOUT1(2)) write(OBIN2,5000) 'Max(RH)',MAXVAL((rh1)), &
'Min(RH)',MINVAL((rh1)), &
'Sum(ABS(RH))',SUM(ABS(rh1))
if(DATAOUT1(3)) write(OBIN2,5000) 'Max(TETA)',MAXVAL((teta1)), &
'Min(TETA)',MINVAL((teta1)), &
'Sum(ABS(TETA))',SUM(ABS(teta1))
if(DATAOUT1(4)) write(OBIN2,5000) 'Max(PD)',MAXVAL((pd1)), &
'Min(PD)',MINVAL((pd1)), &
'Sum(ABS(PD))',SUM(ABS(pd1))
if(DATAOUT1(5)) write(OBIN2,5000) 'Max(FLUK)',MAXVAL((v111)), &
'Min(FLUK)',MINVAL((v111)), &
'Sum(ABS(FLUK))',SUM(ABS(v111))
if(DATAOUT1(5)) write(OBIN2,5000) 'Max(FLUK_dir)',MAXVAL((v112)), &
'Min(FLUK_dir)',MINVAL((v112)), &
'Sum(ABS(FLUK_dir))',SUM(ABS(v112))
if(DATAOUT1(6)) write(OBIN2,5000) 'Max(FLUD)',MAXVAL((v121)), &
'Min(FLUD)',MINVAL((v121)), &
'Sum(ABS(FLUD))',SUM(ABS(v121))
if(DATAOUT1(6)) write(OBIN2,5000) 'Max(FLUD_dir)',MAXVAL((v122)), &
'Min(FLUD_dir)',MINVAL((v122)), &
'Sum(ABS(FLUD_dir))',SUM(ABS(v122))
if(DATAOUT1(7)) write(OBIN2,5000) 'Max(FLUT)',MAXVAL((v131)), &
'Min(FLUT)',MINVAL((v131)), &
'Sum(FLUT)',SUM(ABS(v131))
if(DATAOUT1(7)) write(OBIN2,5000) 'Max(FLUT_dir)',MAXVAL((v132)), &
'Min(FLUT_dir)',MINVAL((v132)), &
'Sum(ABS(FLUT_dir))',SUM(ABS(v132))
if(DATAOUT1(8)) write(OBIN2,5000) 'Max(VXY)',MAXVAL((v141)), &
'Min(VXY)',MINVAL((v141)), &
'Sum(ABS(VXY))',SUM(ABS(v141))
if(DATAOUT1(8)) write(OBIN2,5000) 'Max(VXY_dir)',MAXVAL((v142)), &
'Min(VXY_dir)',MINVAL((v142)), &
'Sum(ABS(VXY_dir))',SUM(ABS(v142))
5000 format(3(a20,': ',e12.5))
l=1
if (i>0) then
l=log10(real(i+21))+1
end if
write(fmt1,*) l
fmt1='(i'//trim(fmt1)//',1x,3(1h.),1x)'
write(*,fmt=fmt1, ADVANCE='NO') i
if (mod(i+1,20).eq.0) write(*,*)
! write(*,fmt='(i1,1x,3(1h.),1x)', ADVANCE='NO') i+32
! write(*,fmt='(3(1h.))',ADVANCE='NO')
! write(*,fmt='(a,a,a,a,a)',ADVANCE='NO') achar(8),achar(8),achar(8),achar(8),achar(8)
!do j=1,14
! write(*,fmt='(a)',ADVANCE='NO') achar(8)
!end do
end do
write(*,fmt='(a16)', ADVANCE='NO') 'finished'
write(OBIN2,*) 'Global maximums:'
if(DATAOUT1(1)) write(OBIN2,5000) 'Max WC',mimaout(1)%max,'Min WC',mimaout(1)%min
if(DATAOUT1(2)) write(OBIN2,5000) 'Max RH',mimaout(2)%max,'Min RH',mimaout(2)%min
if(DATAOUT1(3)) write(OBIN2,5000) 'Max TETA',mimaout(3)%max,'Min TETA',mimaout(3)%min
if(DATAOUT1(4)) write(OBIN2,5000) 'Max PD',mimaout(4)%max,'Min PD',mimaout(4)%min
if(DATAOUT1(5)) write(OBIN2,5000) 'Max FLUK',mimaout(5)%max,'Min FLUK',mimaout(5)%min
if(DATAOUT1(6)) write(OBIN2,5000) 'Max FLUD',mimaout(6)%max,'Min FLUD',mimaout(6)%min
if(DATAOUT1(7)) write(OBIN2,5000) 'Max FLUT',mimaout(7)%max,'Min FLUT',mimaout(7)%min
if(DATAOUT1(8)) write(OBIN2,5000) 'Max VXY',mimaout(8)%max,'Min VXY',mimaout(8)%min
CLOSE(IBIN1)
CLOSE(IBIN2)
CLOSE(OBIN)
CLOSE(OBIN2)
deallocate(rh1)
deallocate(wc1)
deallocate(teta1)
deallocate(pd1)
deallocate(matcls1)
deallocate(x1)
deallocate(y1)
DO I=1,SIZE(MATERIALS1)
DEALLOCATE(MATERIALS1(I)%BLTABX)
DEALLOCATE(MATERIALS1(I)%BLTABY)
DEALLOCATE(MATERIALS1(I)%BMYTABX)
DEALLOCATE(MATERIALS1(I)%BMYTABY)
DEALLOCATE(MATERIALS1(I)%FKTABSX)
DEALLOCATE(MATERIALS1(I)%FKTABSY)
DEALLOCATE(MATERIALS1(I)%FKTABRX)
DEALLOCATE(MATERIALS1(I)%FKTABRY)
DEALLOCATE(MATERIALS1(I)%SORTAB)
END DO
DEALLOCATE(MATERIALS1)
deallocate(rh2)
deallocate(wc2)
deallocate(teta2)
deallocate(pd2)
deallocate(matcls2)
deallocate(x2)
deallocate(y2)
DO I=1,SIZE(MATERIALS2)
DEALLOCATE(MATERIALS2(I)%BLTABX)
DEALLOCATE(MATERIALS2(I)%BLTABY)
DEALLOCATE(MATERIALS2(I)%BMYTABX)
DEALLOCATE(MATERIALS2(I)%BMYTABY)
DEALLOCATE(MATERIALS2(I)%FKTABSX)
DEALLOCATE(MATERIALS2(I)%FKTABSY)
DEALLOCATE(MATERIALS2(I)%FKTABRX)
DEALLOCATE(MATERIALS2(I)%FKTABRY)
DEALLOCATE(MATERIALS2(I)%SORTAB)
END DO
DEALLOCATE(MATERIALS2)
DEALLOCATE(v111)
DEALLOCATE(v112)
DEALLOCATE(v121)
DEALLOCATE(v122)
DEALLOCATE(v131)
DEALLOCATE(v132)
DEALLOCATE(v141)
DEALLOCATE(v142)
DEALLOCATE(v211)
DEALLOCATE(v212)
DEALLOCATE(v221)
DEALLOCATE(v222)
DEALLOCATE(v231)
DEALLOCATE(v232)
DEALLOCATE(v241)
DEALLOCATE(v242)
end program wfddiff
! File: wfddiff.f90
program wfddiff
USE WUFI2DFILE
implicit none
INTEGER :: IARGC
INTEGER :: ARGCOUNT
!in
integer :: l
!out/in
ARGCOUNT = IARGC()
stop
end if
CALL GETARG(1,wfd1)
wfd1 = TRIM(wfd1)
CALL GETARG(2,wfd2)
wfd2 = TRIM(wfd2)
FBPOSIN1 = 1
FBPOSIN2 = 1
stop
end if
do i=1,NDATA
end do
do i=1,NDATA
end do
do i=0,count
wc1 = wc1 - wc2
rh1 = rh1 - rh2
pd1 = pd1 - pd2
v111 = v111 - v211
v112 = v112 - v212
v121 = v121 - v221
v122 = v122 - v222
v131 = v131 - v231
v132 = v132 - v232
v141 = v141 - v241
v142 = v142 - v242
MIMAOUT,NI1,NJ1,i)
l=1
if (i>0) then
end if
write(fmt1,*) l
!do j=1,14
!end do
end do
CLOSE(IBIN1)
CLOSE(IBIN2)
CLOSE(OBIN)
CLOSE(OBIN2)
deallocate(rh1)
deallocate(wc1)
deallocate(teta1)
deallocate(pd1)
deallocate(matcls1)
deallocate(x1)
deallocate(y1)
END DO
deallocate(rh2)
deallocate(wc2)
deallocate(teta2)
deallocate(pd2)
deallocate(matcls2)
deallocate(x2)
deallocate(y2)
END DO
DEALLOCATE(v111)
DEALLOCATE(v112)
DEALLOCATE(v121)
DEALLOCATE(v122)
DEALLOCATE(v131)
DEALLOCATE(v132)
DEALLOCATE(v141)
DEALLOCATE(v142)
DEALLOCATE(v211)
DEALLOCATE(v212)
DEALLOCATE(v221)
DEALLOCATE(v222)
DEALLOCATE(v231)
DEALLOCATE(v232)
DEALLOCATE(v241)
DEALLOCATE(v242)
end program wfddiff
Re: Post-Processing
I'm very new to WUFI and don't know anything about Java or Fortran. Is there a simpler way to do this now? I realize this post is from 2011, surely there is something a bit automated and end user friendly by now?
Re: Post-Processing
What do you want to do? WUFI Graph has become much faster since than, but automatic evaluation still is not possible.
