Pilotis-Heat Transfer Coefficient
Rodopoulos
Post by Rodopoulos » Fri Nov 02, 2018 7:33 pm -1100
Dear All
what sort of Heat Transfer Coefficient would you assign to a surface that is seeing external climate without the solar gains as in the case of a concrete slab on the underside of pilotis?
I am including a picture to better understand the scenario
Cheers
Chris
Pharmacie rentable www.viagrasansordonnancefr.com les soins aux patients
Re: Pilotis-Heat Transfer Coefficient
Post by Christian Bludau » Sun Nov 04, 2018 9:41 pm -1100
Hi Chris,
I would assign indoor, because the radiation part is set that way that it includes the corresponding walls.
In the 8 W/m²K half is convective and half is radiative part.
Rodopoulos
Post by Rodopoulos » Mon Nov 05, 2018 1:37 am -1100
Many Thanks Christian
