I have a question about running simulation in WUFI Plus.
What's the difference between "Maximum Speed" Mode and "Show results" Mode?
Is there any result calculation difference between these two modes?
Thank you!
WUFI PLUS run simulation - Difference between Maximum Speed and Show results
Re: WUFI PLUS run simulation - Difference between Maximum Speed and Show results
No, there is no difference in results. With that button you only switch on/off the visualization, e.g. the temperature and moisture distribution within an componant (if you click on it) during the simulation.
