Design Conditions definition
silmag
Post by silmag » Fri Oct 13, 2017 2:34 am -1100
Hello
I would to clarify one doubt on Wufi 3.0.3.:
If i dont have any heating and/or cooling systems, does it make any difference to define, on Design Conditions, different intervals for Min-Max temperature, or Min-Max Humidity? Does this values have any implication with any feature besides the activation of technical systems. Will my results simulation be the same if i change those intervals, without technical systems defined?
Thank you very much,
Sílvia Magalhães
Sílvia Magalhães
FEUP, Oporto
mwinkler
Re: Design Conditions definition
Post by mwinkler » Thu Oct 19, 2017 8:08 am -1100
Hello silmag,
if you don't have HVAC-systems, the settings in design conditions won't affect your simulations. The Min/Max values in the desgin conditions are used for the respective heating/cooling/humidification or dehumidification device. They also can affect the control of mechanical ventilation, if defined.
Greetings
mwinkler
silmag
Post by silmag » Wed Nov 08, 2017 4:13 am -1100
Perfect.
Thank you very much.
Sílvia Magalhães
FEUP, Oporto
