Hi there
I'm wondering if anyone has data for properties of the adhesive that is recommended to install Calcium Silicate insulation, such as Calsitherm?
Many thanks
Nicole
Calcium Silicate
To provide a reasonable drying potential to the inside the adhesive should have similar properties like the CaSi - so simply neclect it in your simulation.
Another possibility would be to use a vapor permeable adhesive with low liquid transport - in this case use a 1 mm layer of CaSi and switch of the liquid transport to check if this changes or betters the situation...
best regards
best regards
Calsitherm Adhesive properties
Hi there, thanks for the reply. I managed to get the following properties for the adhesive from the manufacturer:
Thermal conductivity [W/mK]0.93
Bulk density[kg/ m³]1410
Porosity [m³/m³]0.468
Spec. heat capacity[J/(kgK)]1059
Water vapour diffusion resistance 35
Re: Calcium Silicate
Hallo!
I`m not able to find a material in the WUFI- Material Data Base, which corresponds to the calcium silicate insulation. Thanks!
There are two Ca-Si-Boards in the database source TU-Vienna.
