Out of Memory Error
Out of Memory Error
Hi
I am using WUFI 2D 3.3 for modelling a typical insulated timber roof. The program is showing me an error "Out of Memory". My hard disk has enough space in all the drives. Please help why I have this error.
Akshay Kumar Gupta
Sustainability Consultant
Building Research Establishment
Hi Christian
I have a grid of 104X140 elements. The grid size was decidd to keep Exp. Fac. between 0.5 and 2. If I reduce the grid size, it will increase the Exp. Fac. which I remember u said (on my email earlier) if outside the said range will give wrong results. Should I make the grid lighter without thinking much about Exp. Fac?
Akshay
Akshay
Akshay Kumar Gupta
Unfortunately... I could not save the file at all. all the options to open, close or save options were greyed (inactive).... so had to close the program which also did not happen as it asked to terminate the program which was already terminated but may be system was not reading it as terminated and I have to forcefully close the program from task manager after waiting 1 hour.
Akshay Kumar Gupta
SindhuMurali
Re: Out of Memory Error
Hi Christian,
I am having a similar issue. I got an 'out of memory' error when the calculation was 63% complete and I am unable to save the file as all options have greyed out; I have enough RAM memory.
I am analysing a rain-screen construction, some of the elements in the detail are quite narrow. I have the grid set to medium in both x and y directions with maximum number of elements in both directions set at 100. I have attached the detail that I have modelled. I am happy to share the wufi file with you if you are able to have a look at it.
Many thanks,
Sindhu
Many thanks,
Sindhu
- wufi detail.PNG (32.62 KiB) Viewed 75415 times
Dear Shindu,
do you have enough space on the drive with the cachedirectory?
See in the menu: Options -> Settings
Hi guys,
I will assume this problem is still not fixed, or is it?
Because I'm still getting the named error after many trials and I also made the adjustments Christian told Akshay to try but always ended unsuccesfully.
In the beggining of my master thesis I could get some good results and all fine but then after some details/projects this error started appearing (sometimes in the beggining of the calculation, sometimes in the middle) and for a few times now it stops just about 0.7 seconds before finishing, making it unpossible for me to save the results
here's a screenshot
https://drive.google.com/file/d/102vS3n ... sp=sharing
Thanks a lot in advance and stay healthy,
Aulona
here's a screenshot
Aulona
